United Airlines flight suffered fuel leak
The place where you can discuss and learn from aviation accidents and or incidents.
avi-addict
Postby avi-addict » Thu Jun 15, 2017 8:58 pm
Propnut
Re: United Airlines flight suffered fuel leak
Postby Propnut » Fri Jun 16, 2017 11:37 am
When fuel is dumped is it not pumped out through the wing tip?
Postby Bell 407 » Fri Jun 16, 2017 9:35 pm
Propnut wrote:When fuel is dumped is it not pumped out through the wing tip?
Proppies, I was going to ask the same thing. That discharge looks like the point where fuel would be dumped from? So maybe a problem with a switch on the ground perhaps.
Postby Raffles » Sat Jun 17, 2017 4:49 am
Possibly a fuel dump valve opened inadvertently or by some technical problem. Another stronger possibility is the "overflow", actually a surge tank at the wingtip to capture excess fuel, may have had fuel in it.
Return to “Accidents & Incidents”
Users browsing this forum: No registered users and 1 guest
