Overland ATR72 destroyed by fire at Lagos Airport
Les Nessman
Wallis and Futuna Islands
Post by Les Nessman » Sat Oct 13, 2018 4:35 am
An aircraft belonging to Overland Airways, parked inside Overland Air hangar at the domestic wing of the Muritala Muhammed Airport in Lagos, is currently on fire.
It is believed the plane was being serviced when it caught fire.
The inferno also spread to other aircraft, causing damages estimated to be worth millions of dollars.
The Fire Service at the airport, have deployed their men to curtail the inferno.
Retrieved from The Daily Post
Re: Overland ATR72 destroyed by fire at Lagos Airport
Post by Raffles » Sat Oct 13, 2018 4:38 am
Date: Friday 12 October 2018
Time: 10:30
Type: ATR 72-202
Operator: Overland Airways
Registration: 5N-BPE
C/n / msn: 316
First flight: 1992-06-25 (26 years 4 months)
Engines: 2 Pratt & Whitney Canada PW124B
Crew: Fatalities: 0 / Occupants: 0
Passengers: Fatalities: 0 / Occupants: 0
Total: Fatalities: 0 / Occupants: 0
Aircraft damage: Damaged beyond repair
Location: Lagos-Murtala Muhammed International Airport (LOS) ( Nigeria)
Phase: Standing (STD)
Nature: -
Departure airport: -
Destination airport: -
Narrative:
The ATR 72-202 suffered substantial damage after a fire erupted while the aircraft was undergoing maintenance at Lagos-Murtala Muhammed International Airport, Nigeria. The aircraft was powered by a ground power unit at the time of the occurrence.
The fire broke outside, on the right side of the fuselage.
https://aviation-safety.net/database/re ... 20181012-1
Post by 87Juliet » Sat Oct 13, 2018 5:22 am
Someone having a ciggie under the wing? Eish, someone has some explaining to do.
Sent from my iPhone using Tapatalk
