Pegasus B738 runway excursion at Trabzon, Turkey
Postby Bell 407 » Sun Jan 14, 2018 1:14 pm
A Pegasus Boeing 737-800, registration TC-CPF performing flight PC-8622 from Ankara to Trabzon (Turkey) with 162 passengers and 6 crew, landed on Trabzon's runway 11 at 23:26L (20:26Z) but veered left off the runway, went down a slope and came to a stop on soft ground just short of the sea about 60 meters before the runway end and about 60 meters to the left of the left runway edge. The aircraft was evacuated. There were no injuries, the aircraft sustained substantial damage.
The airline confirmed the flight had a runway excursion incident while landing in Trabon. The aircraft carried 162 passengers, 2 pilots and 4 crew, all of them disembarked safely, there were no injuries.
The governor of Trabzon reported there were no injuries.
Local emergency services reported 3 people were taken to hospitals with minor injuries.
Mode-S data suggest the aircraft touched down normally at 143 knots over ground.
Aviation Herald
Re: Pegasus B738 runway excursion at Trabzon, Turkey
Postby Bell 407 » Sun Jan 14, 2018 1:16 pm
This really could have ended even worse :frustrated2:
Postby Raffles » Mon Jan 15, 2018 9:46 pm
Short sinopsys of the Pegasus RWY excursion yesterday from an unknown source!:
Fo is pf weather is at minimums. They are expecting to see the runway at minimums. At minimums they see the runway fo disangages the autopilot but at the same time he presses the toga buttons. Captain takes over and lowers the nose and retards both thrust levers to idle, they land at idle thrust and aircraft was dispatched with one reverser inop. Captain deploys the thrust reverser of the left engine and releases the right engine. Since he hadn't disconnect the auto throttle right engine goes to TOGA thrust. Aircraft starts to accelerate and skids off the runway from the left. Right engine saparates. All passengers evacuate the aircraft from the rear door. No smoke in the cabin no injuries.
Return to “Accidents & Incidents”
Users browsing this forum: Google [Bot] and 1 guest
