United Airlines flight suffered fuel leak
avi-addict
Post by avi-addict » Thu Jun 15, 2017 8:58 pm
Re: United Airlines flight suffered fuel leak
Post by Propnut » Fri Jun 16, 2017 11:37 am
When fuel is dumped is it not pumped out through the wing tip?
Post by Bell 407 » Fri Jun 16, 2017 9:35 pm
Propnut wrote:When fuel is dumped is it not pumped out through the wing tip?
Proppies, I was going to ask the same thing. That discharge looks like the point where fuel would be dumped from? So maybe a problem with a switch on the ground perhaps.
Post by Raffles » Sat Jun 17, 2017 4:49 am
Possibly a fuel dump valve opened inadvertently or by some technical problem. Another stronger possibility is the "overflow", actually a surge tank at the wingtip to capture excess fuel, may have had fuel in it.
