FAA: Loss of control
The place to discuss Flight Safety, SMS structures, ERP etc.
Richard Cranium
Post by Richard Cranium » Mon Apr 25, 2016 1:16 pm
What is Loss of Control?
A Loss of Control (LOC) accident involves an unintended departure of an aircraft from controlled flight. LOC can happen because the aircraft enters a flight regime that is outside its normal flight envelope and may quickly develop into a stall or spin. It can introduce an element of surprise for the pilot. Contributing factors may include: poor judgment/aeronautical decision making, failure to recognize an aerodynamic stall or spin and execute corrective action, intentional regulatory non-compliance, low pilot time in aircraft make and model, lack of piloting ability, failure to maintain airspeed, failure to follow procedure, pilot inexperience and proficiency, or the use of over-the-counter drugs that impact pilot performance.
Current Topic:
Investigations of General Aviation Loss of Control Accidents often cite failure to predict aircraft performance, and flight operations conducted outside of the aircraft’s established limitations.
Pilots can start by asking themselves:
* How much can I haul?
* How far can I go?
* How much fuel do I need?
This includes weight of passengers, fuel and cargo.
It also includes departure and arrival runway lengths, obstructions and expected density altitude.
How do I plan?
Start with your crew and passengers, and then add cargo. If these items alone exceed your plane’s capability, you’ll either have to make several trips, or get a bigger aircraft.
You will also need to calculate how much fuel you can take, and whether you’ll have enough to get to your destination, plus an alternative.
Finally, you’ll need to consider your departure and arrival runway lengths, obstructions and expected density altitude.
Be conservative when calculating your plane’s performance, and consider adding a safety factor. Some pilots add 50% to their takeoff and landing calculations for safety.
What’s the greatest variable?
YOU, the pilot, are the greatest variable in this plan. All of your calculations will not mean much if you cannot duplicate them in flight. That’s why it’s important to document your performance capability at least once a year, with a CFI on board. Fly at a typical mission weight, and try to duplicate or simulate mission density altitudes. That way, you’ll know what you and your aircraft can do.
Establish a Baseline
In order to know what performance you and your plane are capable of, you’ll need to establish a baseline. Think of this baseline as a reference point that relates to your performance, and that of your aircraft, under a given set of circumstances on a given day.
High density altitudes and human factors, such as fatigue, will result in performance below the baseline. Proficiency training and lighter loading will likely result in performance that exceeds the baseline. The key point is that for any given flight, your baseline will determine what you need to know about how your aircraft will perform.
What are Limitations?
Limitations are derived from Physical Laws, including:
* Weight and Center of Gravity,
* Speed Limitations,
* Aerodynamic Loading for Normal, Utility and Aerobatic certification categories.
Many limitations are easy to exceed, so you must be careful to operate your aircraft within its limitations at all times.
Tips for pilots
There is no substitute for careful attention to your aircraft’s performance and limitations. Document your performance capability at least annually. Pay careful attention to weight and balance, conditions at your departure and arrival airports, and your expected density altitude. Know your aircraft’s limitations under all conditions, and never exceed them.
Source: FAA
Re: FAA: Loss of control
Post by Raffles » Mon Apr 25, 2016 8:30 pm
We did something similar in the CRM courses, both at Comair and FlightSafety.
There are quite a lot of crashes caused by loss of control.
